Old 07-24-2009, 09:31 PM
Radames Radames is offline
Post Driver side window master switch problems
2002-04 Chevy Trailblazer Master Window Switch
my driver side window dosent work all other 3 switches are working fine,
these are the steps i did so for:
removed the master switch and clean all contacts (dint work)
order another switch from a junk jard (still doing the same problem)
tested the motor from the switch wire down and motor works fine.Meaning that the problems is on the switch, after doing research i found out the switch need some programing from dealer.
daler charge $96 to re-program switch and that didnt work.dealer was asking to much money to diagnost the problem so here i am asking for help from someone that had similar problems.
Thanks
Old 07-25-2009, 04:15 PM
maxwedge maxwedge is offline
A990 racer
Re: Driver side window master switch problems
Look at this schematic there is more than the master involved in this circuit. http://www.autozone.com/autozone/rep...00c1528022aac7
Old 07-26-2009, 02:24 PM
Jethro Jethro is offline
Send a message via AIM to Jethro
he will have to register with auto zone to get that info....
2002 LT Trailblazer 4x4 One of the first of this kind on the road
2003 3500 LT Silverado 4x4 ext cab
2006 Heritage Softail HD FLSTI
Old 07-26-2009, 02:39 PM
A990 racer
Question Re: Driver side window master switch problems
Ok, so did I, 2 minutes, correct?
Old 07-27-2009, 03:50 PM
Smile Re: Driver side window master switch problems
Thanks The schematic work for me.
i traced the digram and find out that there is a separete voltage for that switch , basically under the rear door next to the fuse box the cables where burn , orange cable. due to a screw that came from under the chasis.
i belive this is a common problem with this vehicle.
Thanks for your help. issue resolve.
The Following User Says Thank You to Radames For This Useful Post:
antnee85929 (03-13-2011)
Old 07-27-2009, 06:19 PM
thanks for your help it work. i was hable to solve the problem.
Old 07-27-2009, 06:57 PM
A990 racer
Thumbs up Re: Driver side window master switch problems
Good work and thanks for the reply.
Old 03-13-2011, 09:42 AM
antnee85929 antnee85929 is offline
@Radames!!!!!!!!! It took me 10 mins to reg with this site but I had to tell you that you helped my situation. I have a 02 trailblazer and went through the tough trials of finding the problem. Your post fixed it in 2 mins thank you. My wire was burned under the front door floor panel though. Im so excited because its about to be summer time. :banan adie
Old 05-04-2011, 11:53 AM
AlKHOlIc AlKHOlIc is offline
Sorry, we experienced a technical problem while trying to retrieve this information. Please try again soon. is what i get when i do that link
Old 01-12-2013, 12:57 PM
WashingtonMotors WashingtonMotors is offline
Would someone please tell me how to contct Radames or maxwedge so I can figure out how to access this diagram and establish what color wire is the separate voltage for the switch and where to trace it. I can't even begin to retreive the diagram from AutoZone....I have the same problem and have replaced the switch.......PLEASE HELP!
Old 01-13-2013, 12:18 PM
Blue Bowtie's Avatar
Registered Offender
This any help?
2002 Trailblazer Window Circuit A.pdf
Old 06-21-2014, 06:26 PM
Dare2bdfrt Dare2bdfrt is offline
Thanks for pointing me towards the door jamb wiring... Couldn't understand why occasionally my headlights would dim. Found cut orange wire shorting to ground intermittently... Simple fix now after new door switch and regulator ;-(
