Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 07-24-2009, 02:45 PM
ekks ekks is offline
Question 94 RM won't start
When I turn the key it just goes POP POP POP POP and the interior lights go off and on with each pop. Any assistance is appreciated. Starter?
Old 07-24-2009, 09:11 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 94 RM won't start
Sanitize & tighten the battery cables!
Old 07-28-2009, 11:44 AM
Thanks, I'll give that a try when I get home tonight. I appreciate the help.
Old 07-31-2009, 10:52 AM
Unhappy Re: 94 RM won't start
Didn't work.....still getting the same result....popping/tapping noise when I try to crank it.....not a whirring noise.
Old 08-01-2009, 08:28 AM
HotZ28's Avatar
AF Moderator Elite
Have you had the battery load tested and is it fully charged? Have you checked all the obvious things, like loose cable on the starter, or solenoid? You may have a bad starter or solenoid, but check all the other possibilities first.
