Old 07-24-2009, 10:56 AM
rookieshader rookieshader is offline
fan clutch
97 3/4 ton 4x4 manual tranny... what is a good heavy duty fan clutch?
Old 07-25-2009, 07:36 AM
jonnik jonnik is offline
Re: fan clutch
Have you considered removing the fan and replacing it with an electric fan? I did that with an old Pontiac and was very satisfied with the performance of the fan.
Old 07-25-2009, 08:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: fan clutch
Is your old one bad?
What is it doing or not donig?
Most parts places have cheap and good and best.
Also go for the best.
Or dealer OEM fan clutch.
MT
Old 07-26-2009, 10:26 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: fan clutch
I'll have to agree with going with the better brands, especially if you're doing a lot of hauling and trailering. They are usually listed as "heavy-duty". Get the best one that you can afford.
I personally would like to replace mine with an electric fan. I can't stand all that roaring fan noise when the truck is driven after the engine is first started from cold. Sounds like I'm taxiing an airplane down my street....sorta.
I have seen various aftermarket fan setups, but also have seen some threads about electric fans from Corvettes modified to fit. Either way, that is a ~$300+ change out (fan, temp controller, harness, etc) and not much HP gain per buck, so it is low on my to-do list. But since you're note having to cool the transmission fluid, you're cooling requirements may be lower.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
