Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-24-2009, 10:34 AM
RCTC RCTC is offline
96 Cutlass Supreme A/C problem
A/C doesn't blow properly/cuts out when accelerating. Also, low coolant light comes on after driving a while. When checked, the resevoir is at the appropriate level. I was told to check the vacuum lines. Is there a site to get a diagram of the vacuum lines? Thanks
Old 07-24-2009, 04:30 PM
thisnametooktolong thisnametooktolong is offline
Re: 96 Cutlass Supreme A/C problem
After you get the plastic covers off, I think that you will find that there are not enough vacuum lines on it to confuse a 10 year old.
But what on earth do you mean that the AC stops when you accelerate? Please be more specific. Do you mean that the fan stops? or are you refering to the fact that at WOT the compressor turns off. ( it is supose to do that on many models)
