Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-23-2009, 11:49 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
DIS BOX help
Ok i've posted here, on msd technical support forum, and still cant get an answer...if anybody happens to see this post and know the answer, please tell me...
Application-97 rs n/t w/ turbo
Problem-If I already have a fuel controller, and tach adapter, and I get a DIS box to tune the ignition, do I wire it into the tach adapter? Because when you look at the item desc. for the DIS box, it says "goes great with one of our tach adapters..." SinceI already have one, is it vital that I wire them together?
Thanks!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 07-25-2009, 08:38 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: DIS BOX help
I have never used one of their systems before but I believe you use the tach adapter to make the stock tach work again. The signal coming from the ECU goes to the MSD box and then you connect your stock tach wire to the adapter.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-25-2009, 10:47 PM
Re: DIS BOX help
ok, i finally got an answer from the msd tech. support forums...heres what the guy wrote...
"The Dual Ignition adapters that are used with the MSD DIS boxes are used to restore the "kickback" signal that the coil normally produces and the factory ECM uses this for the fuel injection system. The adapter you received from SplitSecond should be something different. I was not able to locate this on thier website.
Would you be able to provide the wiring instructions for the adapter?"
and i replied that i would send the info he requested....
