Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-23-2009, 04:03 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
supercharged boost issues?
hey, i got a 2000 trans am..many many mods..including ported heads..big cam..alot of top end..i have the powerdyne set up..supposed to run around 6 psi..im only making 2 psi currently on the stock pulley which im told is 3.25..im gonna try to put a 2.93 pulley on and see if that ups the boost? im thinking all the upgrades on the car are actually holding the supercharger back, since there made for stock cars..any ideas
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 07-24-2009, 12:46 PM
MrPbody MrPbody is offline
AF -Advisor
Re: supercharged boost issues?
You say "upgraded cam" and "big cam". Can you be more specific? Duration @ .050 lift and LSA are important parameters in an engine like this one. A "hot" cam for a streeter may not be a good choice with the blower. While it may affect power production, it shouldn't reduce total boost in the plenum, but I suppose it MIGHT.
Jim
