Old 07-23-2009, 02:22 PM
steve200858 steve200858 is offline
97 chevy p/u tranie problem
please help, i have a 97 1500 with the L460 trans, in the morning when truck is cold i start out and it shifts fine through all gears and if i dont have to slow down or stop ( not let it drop out of overdrive ) it will go forever, but if i slow down it will drop to third and will not go back into overdrive, if i stop it drops down to first , but when i start going again it shifts HARD to second then goes into default (2 and 3 only) if i shut the truck off and start again it shifts hard to 2 then defaults? flushed and replaced filter and the two shift solnoid , but was no help any ideas? Thanks
Old 07-23-2009, 04:36 PM
2000CAYukon 2000CAYukon is offline
Re: 97 chevy p/u tranie problem
A Trans capable scanner should be used to check for stored codes when the problem occurs.
To me, this sounds like a valve body issue that you are loosing pressure when hot. The tranny then goes into limp mode (firmer shifts).
You don't list the mileage; however, the valve body should be removed and checked for wear. The spacer plate could be worn (check ball wear).
Another option is a Transgo kit which addresses some of the 4L60E weaknesses.
//2000CAYukon
Old 07-30-2009, 05:14 PM
thanks for your answer the kit you said is it the shift kit?? Thanks
Old 07-31-2009, 03:31 PM
Yes. https://www.700r4l60e.com/store/prod...&cat=64&page=1
//2000CAYukon
