Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-23-2009, 01:31 PM
gfsrch gfsrch is offline
Serv. Eng. "mystery"
Replaced all 4 O2 sensors in response to Serv. Eng. light and code indication.
Reset computer, started car and car ran for approx 1/2 hour without Ser. Eng light on then light came back on. Had codes checked and two codes gave the following;
1. EVAP canister vent control valve (close) - no purge detected during purge event. Probable cause.
A) Hoses connected incorrectly
B) Failed canister purge solenoid
C) Failed fuel tank pressure sensor
D) Open circuit condition
2. Catalyst system below threshold - bank 1
Probable cause
A) Large vacuum leak
B) Rich AF ratio - fuel system fault
C) Ignition system malfunction
D) Faulty Cat. Conv.
After resetting computer (car sat for 2 hrs), started again and no "Ser. Eng" light... drove for approx 1/2 hr and light came on again with same codes. I would assume delay rules out A) & D) in #1 and A), C) & D) in #2... I was considering replacing the fuel tank pressor sensor but am at a loss, any ideas, suggestions or advice?
Old 07-23-2009, 08:14 PM
Mrbizness1 Mrbizness1 is offline
Re: Serv. Eng. "mystery"
What year is the car? From my experience evap codes will set of other codes, so you should fix the evap one first. The cars computer checks for some codes at different times, so clearing the code turns off the light until the next checkpoint. Most evap codes are set off by problems with the evap canister or the purge solenoid that is attached to it. These links provide a lot of info.
Most Nissan products have similar systems.
http://www.automotiveforums.com/vbul...d.php?t=445827
http://www.asashop.org/autoinc/feb2006/techtips.htm
http://www.nissanclub.com/forums/eng...rol-valve.html
http://www.nissanforums.com/sr-serie...ve-closed.html
Old 07-29-2009, 01:26 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Intermittent mysteries tend to be related with connector oxidation. Cleanup job...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
