Old 07-23-2009, 10:55 AM
Joe Wilson Joe Wilson is offline
Smile Parking Brake
I noticed recently that the parking brake on my 98 S-10 doesn't stay engaged when I push the pedal down. The brake works just like the regular brake, push it down and it works but doesn't stay working. I tried messing with the hand release and pushing the pedal down harder but it stays the same. I would guess it's in the pedal mechanism. Am I right?
Old 07-23-2009, 08:21 PM
j cAT j cAT is offline
Re: Parking Brake
I found on the 1994 s10 that the release mechanism is rusted and sticks,,,,,or the cable sheathing is binding on the inner cable...
spray this area with some wd-40....
Old 07-26-2009, 10:19 PM
Smile Re: Parking Brake
Is the parking brake pedal and mechanism easily removed for repair?
Old 08-21-2009, 04:24 PM
DoCTa09 DoCTa09 is offline
Re: Parking Brake
I had this same problem..the pedal assembley comes out rater easily. I found when the assembly was out that the plastic inside the assemble which holds the spring in place was cracked and therefore was not allowing it o ratchet and latch. Resolution..buy a new assemple for around 100 bucks.
Old 08-22-2009, 12:30 PM
phammerjr phammerjr is offline
Re: Parking Brake
I had the exact same problem on my 02. I just bought a new one for 75 bucks. it is a pain getting up under the dash to do the replacement. also is pretty tough to get the lever assembly disconnected from the brake cable.
Old 08-22-2009, 09:56 PM
Anyone know of a good place to buy the assembly?
Old 08-23-2009, 11:28 AM
Re: Parking Brake
Doesnt get much cheaper than the dealer..
Old 12-07-2009, 05:03 AM
16th hippy 16th hippy is offline
Re: Parking Brake
know this thread is a few months old, but have to agree with J-cat's method. is just a lack of lube. had same problem on my 98 s-10. if not fixed yet, move seat all the way back and lay down on floorboard(NOT comfortable) so you can see the release cable and the little lever it is attached to. push this little lever toward the engine compartment, if it moves slightly, then try to set parking brake. if it sets AND holds, then just apply the lubricant as J-cat said. wd40, pb blaster, or whatever you prefer. if this does NOT solve the problem, then a new assembly will most likely be required. good luck.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
