Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-22-2009, 11:51 PM
chryslerconcordeLX chryslerconcordeLX is offline
starter problems
hello I had just recently bought a 1997 Crown Victoria LX with 33.000 miles and the starter needs to be replaced. I was wonder anyone could help me. I was wondering what is the best was to remove the starter?
Thanks,
Jeremy
Old 07-23-2009, 07:34 AM
rhandwor rhandwor is offline
Re: starter problems
Put the car on 4 jack stands. Remove the negative battery cable. Use a 1/4 drive socket set and remove the wires to the starter. Then use a 3/8 drive socket set with various size extensions and remove the bolts holding the starter in place. After the bolts are removed remove the starter. Sometimes you might need a flexible socket.
http://www.ebay.com/ item 250469703196
Even if you don't need them on this job if you do much work you will need them. A lot of places sell them.
Old 07-23-2009, 11:43 AM
Thankyou for helping. I will see what I can do this afternoon. I was just wondering, do you have experience in removing starters in a crown victoria? Is is a hard or easy job to do? I have all the tools.
Old 07-23-2009, 12:24 PM
I'm retired at this time it used to be easy when the car was on a lift. I remember older Crown Vic's it may have changed some but should be close.
Old 07-23-2009, 06:36 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If it is the original starter, it will have 3 bolts. The bolt on top will be hard to get to. Take your time and you can get it. The top one is in a tight place to get to. Follow rhandwor's advice also.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-24-2009, 02:30 AM
thanks guys for all your help.
