Old 04-03-2003, 07:22 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
Anyone?
Is there anyone here running 4 ohm 12" JL w0's? If sowhat size of amp r u using. I have 2 in a sealed box, and am not sure what size or what setup to go with. The subs ARE dual voice coil. Which setup would be best, parralel or series? Also would i need an X-over?
Old 04-03-2003, 11:18 AM
bumpity bump
Old 04-03-2003, 12:31 PM
91civicDXdude's Avatar
It all depends on the amp.
If you hooked each set of voice coils up in series, you would have two 8 ohm speakers. then hook each speaker together in parallel and the amp bridged, you are now running a 4 ohm mono load, which on a non compeition series amp is the best configuration since it is using the most effiecient power.
ideally, if you had an amp that was 1 ohm mono stable or so, you would want to parallel each set of voice coils (two 2 ohm speakers), and then parallel each speaker bridged at the amp. This would make a 1 ohm mono load and put out mega power, but most amps cant handle this.
You cna also hook up any amp as a 2 ohm stereo load by hooking up each set of voice coils in parallel and then running those sets each off of one channel of the amp. a 2 ohm stereo load is the same wattage as a 4 ohm mono load, only the mono load is bridged so its making more effiecient power.
If you have a run-of-the-mill amp, 4 ohm mono load is what you are looking for. If you have a competition series amp, run the lowest ohm-age possible.
Part 2:
You will need a crossover unless you have a bandpass box which you do not. You will want to set your lowpass crossover @ about 120hz or so depending on what type of music you listen to.
Old 04-03-2003, 12:36 PM
If you need help, here is a link that explains it in better detail:
http://www.eatel.net/~amptech/elecdisc/spkrmlti.htm
Old 04-03-2003, 01:38 PM
so wut ur saying is that i need a x-over if i want pure bass?
Old 04-03-2003, 05:21 PM
yes. a crossover is necessary on subwoofers unless you have a bandpass box which you do not.
Old 04-03-2003, 07:17 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
lots of amps now come with built in hi/lo-pass filters, some even variable, and you still need a crossover on a bandpass box. and the crossover point depends entirely on your configuration.
Old 04-03-2003, 07:27 PM
so u dont need a x over with sum amps?? or should i go pick one up anywyas?
Old 04-03-2003, 08:09 PM
depends on the amp. if the amp says it has a built in crossover or a low-pass filter built in, then you don't need one, but otherwise you will.
Old 04-03-2003, 08:18 PM
iight sweet, this has helped me out a ton, my next problem is figuring out what setup i need, but i guess it wont matter till i get my amp. Would a 400 watt 2 channel amp run the JL 12"w0's good? i think their rated at 125 RMS
Old 04-03-2003, 08:58 PM
yeah, keep the gains low on the amp. JLs tend to be able to take a little more power than they are rated at. but if you hear the subs distorting, turn it down.
Old 04-03-2003, 10:14 PM
you dont necessarily need a crossover with a bandpass box. The box deesign itself works as a crossover. Its still a good idea to have a crossover so the voice coil isnt receiving signal that it cant reproduce, but technically, you dont need a crossover. the box has to be tuned, thus working as the crossover.
