Rearend rattle
I purchased an 01 with 56,000 miles and i have had it about 6 months now and it has developed a rattle like something is loose but i can't find anything wrong. it doesn't seem to effect the ride but it's just really annoying. Is this something that is common?
Thanks |
Re: Rearend rattle
check the spare tire. Sometimes stuff gets kicked up and will sit in the rim
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
Re: Rearend rattle
Another thing that I have had rattle is the wheel covers (hub caps), the factory ones have plastic clips....which break....
Also stones inside will do that. If the shock absorbers have been changed, the big bolts ( 1 at top, 1 at bottom) on the shock absorber may need re-tightening. Does it have a trailer hitch?, the receiver (part with the ball) can rattle inside the hitch frame. I bought a anti-rattle clip to quiet mine.....and it works These (and the spare tire) are some easy things to check first. Otherwise......a look around from underneath is in order.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
Re: Rearend rattle
its is coming from the driver side close to the wheel I'll check the shock bolts this weekend but it is not the spare, or the hitch and it has alloy wheels and it makes the noise with or without the center caps
Re: Rearend rattle
Shocks it is. Thanks for the Help
Re: Rearend rattle
Thanks for posting the solution.
I really like the cheap and easy solutions.
