Old 07-22-2009, 01:23 PM
Greg5150 Greg5150 is offline
3800 Missing under load - problem solved
I just wanted to share a solution with the board: I have a 1997 Park Ave which began missing under load. A new set of spark plug wires solved the problem. Interestingly I replaced the wires when I got the car about 80,000 miles ago. I guess 80,000 miles is the lifesoan for plug wires. I used Bisch wires from Autozone.
Old 07-22-2009, 07:25 PM
auto trainy auto trainy is offline
Re: 3800 Missing under load - problem solved
Thank's for the feedback,80k is not bad for wires,did you get that with the Bosch or did you replace them with Bosch? The reason I ask is because GM engines like Delco but if you got 80k with Bosch that's not bad.
Old 07-22-2009, 10:28 PM
Yes, when I installed new wires 80k miles ago I used Bosch which I bought at Autozone. I also used Bosch today when I replaced the wires. The wire set was only $27.99. Another interesting thing was that the missing problem happened suddenly, it did not occur gradually.
I was thinking of buying GM wires but I needed to solve the problem asap and if I bought GM wires at the Buck Stealership down the street I probably would have paid twice as much as the Bosch wires.
Old 07-23-2009, 06:48 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
You can purchase ACDelco wires @ Advance-O'Reilly for 47-bucks a set; however, if you got 80K out of the Bosch "China wires" that's not bad!
Old 07-25-2009, 08:29 PM
Surprisingly the Box for the Bosch wires says "made in USA". The only reason I bought them is because I got so many miles from the set I bought a couple of years ago. I think they ok considering the cost.
