Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 07-22-2009, 12:22 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
keep breaking trans mounts need help
well it is what it is 89 iroc keeps breaking trans mount every couple weeks
i know i shouldn't solid mount it but why dose it keep breaking them. the only thing i can think of is when the car hooks the torque arm is pulling on it too hard is there a way to mount the torque arm to maybe the cross member or the floor thanks in advance
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 07-22-2009, 09:45 PM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: keep breaking trans mounts need help
check your eng mounts all mounts work together each taking there share of the torque from eng to rear, sounds like your tranny mount is taking more then its share of a twist torque since the rear end is not dirrectly attached to tranny but through a drive shaft driven by a twist torque. i up wind back at eng which is directly attached to tranny and if eng twists so does tranny
Old 07-25-2009, 07:15 PM
yeah the motor mounts are brand new about 700 miles ago, it is however heavily modified i did figure out a way to take the torque arm mount off the tail shaft im thinking this will help
