Old 07-21-2009, 09:04 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
p1406
i was driving my truck to my gf's house and i noticed the entire way i had almost no power. then when i got there it was idling rough. i revved the motor and no difference. i shut it off. waited for a min and started back up and still no difference. revved it again and then the motor smoothed out and the ses light came on. i know it deals with the egr but i'm thinking it has to do with one of the sensors feeding it. i've cleaned it before and i know what it felt like before when it had gotten carbon in it. does anyone know what sensors it uses? its the 95 cpi with the obd2 computer with the electronic egr.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 07-22-2009, 09:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: p1406
What is the code no.?
How is the tune up and fuel pressure?
Plull egr valve and check for carbon under punger.
As far as sensors the have a lot of them.
Proper testing will show if any are bad.
Start with the code it has.
MT
Old 07-22-2009, 06:54 PM
Re: p1406
the code is a p1406. tune up has been with in a year. fuel pressure i've never checked. but it runs good when you floor it. replaced fuel filter 1 week ago. what sensors help control it so i'll know which ones 2 check.
Old 07-22-2009, 07:36 PM
MT-2500's Avatar
AF - Advisor
Re: p1406
Sensor will not help unless yoou have a bad one.
The code is for EGR valve pintel position does not match actual desired position.
May have got a carbon ball under plunger.
Is it running good and idleing good now.
Have you cleared code and see if it returns.
Also run a fuel pressure test and post back readings.
MT
Old 07-22-2009, 07:41 PM
MT-2500's Avatar
AF - Advisor
Re: p1406
Vin w 4.3 look for 55/61 fuel pressure readings and make sure to test it on the road hot after 20-30 minute drive.
Give us the fuel pressure readings.
Cold eng cranking and run ing and hot running and on the road readings.
And pinch off or block a return line and post back all readings.
MT
Old 07-22-2009, 09:17 PM
Re: p1406
would it give a false code if fuel pressure was low?
Old 07-23-2009, 07:25 AM
MT-2500's Avatar
AF - Advisor
Re: p1406
No the code is for a egr valve position sensor not matching actual and desired position.
But for it to run right you need proper fuel pressure.
We need more info to help you.
Did the code clear and stay cleared?
Give us you fuel pressure readings.
MT
