Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-21-2009, 01:27 PM
stowerh stowerh is offline
Question 1998 Ford Mustang GT Shifting Problems
I have a stock 1998 Ford Mustang GT with manual transmission. Recently the transmission was replaced, and I am now experiencing a problem when shifting. The transmission shop says it is not the transmission itself. When I shift into gear, unless I push hard to engage, it will pop out of gear. Is it the transmission, the clutch, the shifting mechanism, or a connection to the transmission? I'm not even sure where to begin.
Old 07-21-2009, 04:48 PM
drewbie09 drewbie09 is offline
Re: 1998 Ford Mustang GT Shifting Problems
It is most likely your shift syncro's in your transmission. They are telling you that because it will be their fault and they will have to fix it.
Old 07-21-2009, 05:02 PM
What do I need to do to prove that is the problem?
Old 07-22-2009, 02:45 AM
Davescort97 Davescort97 is offline
Escort guy
Welcome to AF!
It's either the transmission or the shifting mechanism.
There are about 9 things that could keep it from staying in gear. 5 of these are related to the internals of the tranny. They are:
1. Worn shifter fork.
2. Worn synchronizer hub or broken sychronizer spring.
3. Worn synchronizer sleeve.
4. Excessive thrust clearance.
5. Worn bearings.
If the tranny shop put in a rebuilt these things probably aren't the problem. If they they rebuilt the tranny themselves, I'd say they have a problem.
The way they put the tranny and shift linkage back in could cause it to jump out of gear if they didn't do it right. If the shift linkage was damaged or the gear shift lever support shaft spring was weak it could cause it to not stay in gear. Also, if the gear shift lever socket bushing is worn it could keep it from staying in gear.
No matter how you slice the cake, they did the work, they put it in and they should stand behind their work. Saying it isn't this or that is just putting you off. Sadly, there is no way you can prove that the synchronizers are bad unless you have it torn down and inspected. Stay after them. Since you say you had it replaced I assume you had a new or rebuilt put in. Take it back and have them check all the linkage and the rear tranny mount. If you had a rebuilt or new tranny put in there should be a warranty on it. If it was a used from the boneyard they should still make good on it for at least 90 days. Remember. The squeaky wheel gets the grease. Be a PITA! If they say it's not this or that, say back to them, Well, what is it?
Old 07-22-2009, 10:15 AM
Thanks for this information. I will definitely take it with me as I continue to push.
I was hoping their was a way to know for sure, but it sounds like it is by trial and error. It seems awfully coincidental that this started after the transmission was replaced.
The problem is that the transmission shop doesn't work on the shifting mechanism, pretty silly. So, I guess I have to take it to my regular mechanic for that before I pursue the other.
If it doesn't turn out to be the problem, I will definitely be their "squeakiest" wheel.
Thanks again.
Tags
shift
