Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-21-2009, 12:52 PM
keonjordan keonjordan is offline
Question Front Tires will not rotate clockwise!
I recently had my 2003 Impala towed to my house. After the car sat for a week, I attempted to drive it around town. Driving forward is no problem, but when in revers the front wheels lock for some reason.
Has this happened to anyone? Are my axels bad or hub bearings shot? Any help in finding a solution to this problem would be greatly appreciated!
Old 07-21-2009, 01:09 PM
rhandwor rhandwor is offline
Re: Front Tires will not rotate clockwise!
Put the front end on jack stands and remove both front tires. Block the rear wheels have somebody else put it in gear and watch. Is the brakes grabbing if not I think the transmission is causing the problem. Normally a seized bearing is going to stop you in both directions. Does it stall the motor in reverse or is it not going into gear. If this is the case check the shift linkage.
Old 07-21-2009, 02:21 PM
Thanks, I will try this and let you know what I find!!
Old 07-24-2009, 07:46 PM
j cAT j cAT is offline
sounds like shift linkage is out of adjustment..
