Old 07-21-2009, 05:35 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Losing coolant
I'm having to add about a gallon of coolant every few weeks, maybe three. Can't see where it is leaking anywhere and the oil analysis did not show up any in the oil.
Does this mean it is burning out the exhaust? Haven't seen any smoke or smelled anything unusual. I only have 371,000 miles and it still runs good. I can tell when it's getting low because the temp gauge will go up when I slow down or stop. What gives?
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 07-21-2009, 07:03 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Losing coolant
only have 371k,
Didn't you just do an LIM/UIM job Wally?
If so, I hope you don't have a head gasket issue with your mileage.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-21-2009, 03:05 PM
smokebeast smokebeast is offline
Re: Losing coolant
I'm having the same issue. I already did the UIM/LIM gasket about 10K miles ago. Worked for a while, but now I'm losing more coolant than ever, but none in the oil. Can't find the leak anywhere by inspection, all the hoses are good. I took it to a shop to have it diagnosed, but when they pressurized the system they just blew out the seal on the that coolant 90 deg. elbow on top of the water pump. What else can be leaking? Water pump gasket? Front cover gasket?
Old 07-21-2009, 06:40 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Losing coolant
pull the plugs Wally and check for discoloration.
Also check your water pump/bypass elbow area.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-21-2009, 11:35 PM
wlkjr's Avatar
Re: Losing coolant
You mean pull the front three plugs, don't you. I'd rather be kicked in the gonads than deal with those back three plugs again.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 07-21-2009, 11:40 PM
wlkjr's Avatar
Re: Losing coolant
Originally Posted by richtazz View Post
only have 371k,
I think it was 3 years ago when I did the LIM/UIM job, somewhere just over 300,000 miles. I can't find any dripping but I am finding some greasy, oily looking spots about 10 inches in diameter, on the driveway. And the front side of the oil filter has that same residue on it.
The water temp only seems to go up when it gets low on coolant. Sure hope it's not a head gasket. I suppose that would give me a chance to practice my mechanical skills when I retire in 2 weeks.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 07-22-2009, 12:19 AM
tblake's Avatar
In God We Trust
Re: Losing coolant
The back 3 arent so bad. I'll come over and yank them out for you. Just get one of those swivel spark plug sockets for the one blocked by the O2 sensor. You'll be fine.
I have a feeling that if your car was consuming coolant through the head gasket, that you would also have combustion gasses entering the radiator. Fill it and leave the cap off and check for bubbles at idle and blip the throttle. Maybe your UIM has warped (didnt your replace it ones already?)
After I did my LIM gaskets, mine lost coolant out the temp sensor and the t-stat o-ring. The temp sensor appeared dry and I kept on replacing the t-stat gasket because I thought it was dripping from there. It would lose about half the radiator in a few days. Then I finally rented a coolant pressure tester and pumped it up. The rest is history.
BTW, congrats on retirement.
Old 07-22-2009, 12:24 AM
wlkjr's Avatar
Re: Losing coolant
Already got the swivel socket for the plugs, so come on over. I have replace the upper intake manifold. Just threw the old one away last month and it was not in bad shape.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 07-22-2009, 07:45 AM
toddman67 toddman67 is offline
Re: Losing coolant
Get a combustion leak detector test done on the cooling system to confirm head gasket issue. Some retailers sell the test kits, otherwise find a radiator shop to test.
Old 07-22-2009, 08:42 AM
richtazz's Avatar
Re: Losing coolant
Do you see any horse residue anywhere Wally? some may be blocking airflow through the radiator,
Old 07-22-2009, 05:27 PM
tblake's Avatar
In God We Trust
Re: Losing coolant
Wally, I just ordered my plane ticked to georgia. One Way, I figure I will just move down there so I dont have to deal with the salt in the winter here. See you in about 2 weeks!
Old 07-22-2009, 11:31 PM
wlkjr's Avatar
Re: Losing coolant
So you'll be here in time to go to the night race in Atlanta on Labor Day weekend? I'll save you a ticket.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 07-23-2009, 12:55 AM
tblake's Avatar
In God We Trust
Re: Losing coolant
You know it! Thanks! (I wish)
Old 07-23-2009, 01:23 AM
wlkjr's Avatar
Re: Losing coolant
Tim, you should be in bed asleep.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 07-23-2009, 09:48 AM
tblake's Avatar
In God We Trust
Re: Losing coolant
Your right.
I just had to check my email quick, waiting on a reply about a new job....
Any word on the coolant leak?
