Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 07-20-2009, 07:59 PM
JJ122 JJ122 is offline
general, but indepth suspension question
Ok so the main issue I am having is with road noise. The volume is dependent on both the speed and surface of the road. My 2 main ideas are the shocks and hub bearings. I am about 95% sure that they are both factory originals. The shocks fail the bounce test, so I plan on getting them replaced. I might get the eibach "Pro-system" kit with shocks and springs, its only like $150 more then stock replacements (any comments on this?). And while my suspension is apart would it be a good time to get my bearings checked out/replaced?
So the question is: does what I have said sound correct? Is there anything else that should be looked into?
My car is a '93 Del Sol Si, obviously no suspension mods.
and I'm posting it here because it seems like no one ever goes to the del sol section any more.
Thanks JJ122
'93 Honda Del Sol Si stock (AT)
