Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-20-2009, 08:31 PM
wesk18 wesk18 is offline
2002 tahoe problems!
My rear ac stop working the front works gives me a weird odor n it leaks water near the front wheel??
second problem my front wheel is making a noise while driving a mechanic told me it was the wheel bearing so i replaced the left side but still the noise is there can it be the front axle assembly??
third problem, while driving at slow speeds a squeeking noise i could heard but cant tell from where, what can it be??
thanks
Old 07-21-2009, 09:20 PM
roadrunner2 roadrunner2 is offline
Re: 2002 tahoe problems!
thanks
I also have an '02 Hoe and the A/C in mine pushed out warm air in the front and cold out the back.
A new electric blend door motor fixed it.
The A/C condensor drain is close behind the right front wheel and if you use the A/C, that's where the water will appear.
I can't help with the other two questions from here.
The problem with doing nothing is not knowing when you're finished.
Old 07-22-2009, 09:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
thanks
Is rear air fan working?
Does ac have the proper charge?
Water leak underside is good they all do that.
On wheel bearing noise did you not check the other side to?
Does the noise cange when going 30 50 MPH down the road when turning the steering wheel just a little bit?
Is the squeekling coming from a front wheel and which side?
MT
Old 07-22-2009, 04:15 PM
the rear fan is not working only the front but not as good as before so it might need a charge.
the wheel bearing noise got louder at higher speeds, when steering to the right on a curve the noise seems to lower
the squeeking is coming from the right side not sure if its the front or rear
Old 07-22-2009, 04:46 PM
MT-2500's Avatar
AF - Advisor
Sounds like you need to replace the other wheel bearing.
Was the one you replace bad?
You need to get the rear fan working good.
what speeds is front fan working on.
What is the vent tempt front and rear?
Also make sure you have a full charge.
Low charge will knock out one end of AC.
MT
