Orifice Tube and Low Pressure Switch bypass
1. Where is the orifice tube located on a 2000 GT GP?
2. How do I by pass the low pressure switch so the compressor clutch will engage to accept more freon and recharge the system? The system is out of freon so is currrently holding no pressure. I have dual climate control with a V5 compressor. |
Re: Orifice Tube and Low Pressure Switch bypass
the orifice is located in the high side line on the drivers side of the vehicle near the accumulator (under the hose between the air filter box and the t/body.
Because there is only one pressure switch, it cannot be easily "jumped" to force the compressor to kick in.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
How do I then force the compressor to engage the clutch to accept freon during a recharge. All of the freon leaked out because of a poor shaft seal on the compressor. I already replace the compressor.
You should get enough pressure or refrigerant charge to overcome the low pressure side of the switch with the first can of R134a and eventually the compressor should kick in. I had no problems with a fully evacuated system that required work on the V5 compressor.
As long as a vacuum has been pulled it should take the freon charge. But is there was no vacuum it is very hard to get the system to take an initial charge. Plus since the system was opened to replace the compressor you need to pull a vacuum in order to boil off any moisture that entered the system when the compressor was replaced.
![]() Isn't evacuating a system the same as pulling a vacuum on the system which is standard practice or auto A/C 101 basics? Or maybe we should parse the term "recovery". ![]() Quote:
Yes it is the same thing. Been kinda of out of it with a lot of lower back pain. This weather sucks when the temps at night go down to the mid 50.
