Old 07-19-2009, 11:08 PM
dominicus777 dominicus777 is offline
96 2.2L crank/no start...keep reading
I have searched online for days and googled my brains out here. So here it goes...
1)Cranks but no start. No fuel pump action.
2)Fuel pump works (jumpered it and have 2nd pump does same) and relay works (tested that too!) Test lighted the relay socket with no power from PCM.
3)Theft light stays on (NO BLINK). Code reset does not work. PCM is not turning on the pump. PASSLOCK 1 shuts off fuel injectors by use of the PCM turning off the pump.
4)ALL fuses are fine. Original cluster still.
The trouble is this, the PASSLOCK allows the PCM to prime/power the pump. BAD lock cylinder = PASSLOCK LIGHT and BAD PCM = PASSLOCK LIGHT too. So... is it my lock cylinder with a bad PASSLOCK sensor or my PCM? Electrical map that I have followed all over with markers leaves these two options.
Please no BS here. If you dont know please pass it along.
Old 07-27-2009, 03:39 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 96 2.2L crank/no start...keep reading
Maybe too late to help, but here goes...
What I would do is disconnect the lock cylinder and put a resistor between the yellow and black wires (I know 3k to 6k ohms work, but I forget the whole range). Try learning that "code", if it starts, you have a bad lock cylinder, if it doesn't work, bad PCM. Remember, you have to do the 10 minute thing 3 times when learning a new resistance. If starts that way, you can leave the resistor in if you don't want to buy a new lock cylinder.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-28-2009, 10:24 PM
Thank you. I hope this works lol. Its been with me for so long I cant let it die yet.
