Old 07-19-2009, 10:53 PM
longslide longslide is offline
tranny conversion
how hard would it be to install a manual tranny in a blazer that was a auto?
Old 07-20-2009, 07:57 PM
old_master's Avatar
Advisor/Moderator
Re: tranny conversion
Lotta work, lotta money, but it can be done.
You have to know how it works,
to figure out why it doesn't.
Old 07-21-2009, 11:39 AM
how much work would be involved?
Old 07-21-2009, 04:54 PM
old_master's Avatar
Advisor/Moderator
Different bell housing, different drive shaft, possibly a different crossmember, flywheel instead of flex plate on the engine, complete clutch linkage, clutch master and slave cylinders, brackets, lines, etc. Different PCM, wiring harness under dash for starter interlock, different brake pedal & linkage, and depending on wheather your shifter is on the floor or on the column now, the shift interlock will need to be re-worked. Off the top of my head, that's a start. I'm sure if I thought about it, I could come up with more. Maybe someone that has done it will chime in.
Old 07-21-2009, 05:57 PM
so if i was going to stick with a auto what auto would be best?
Old 07-21-2009, 07:05 PM
old_master's Avatar
Advisor/Moderator
What year, make, model, and what is the 8th character of the VIN?
Old 07-22-2009, 10:40 AM
its an 86 2 door i dont have the vin right now. but it donsent have a engine or tranny so i get to start from scratch. i was just wondering what trannys were good. i am pretty sure it had a 700r4.
Old 07-22-2009, 03:33 PM
old_master's Avatar
Advisor/Moderator
The 700R4 was used on a lot of V8 engines and is actually over-kill on a 4.3L V6. Good choice for your Blazer.
Old 07-23-2009, 12:51 PM
ok sounds easy to find a 700r4 to put in used ones are all over on craigslist. i will probably get one and have it rebuilt.
