Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-19-2009, 08:14 PM
cadvette cadvette is offline
Ignition timing bypass mode
I have a 1992 GMC Sierra with a 5.7 and manual trans. Just had the heads redone. Running fine ,but I would like to check the timing with timing lite. The only trhing is I can't figure out where the wire is that you are supposed to disconnect to get into the bypass mode. I know that it is a tan with black stripe single wire but I can't seem to find it. Could someone please tell me where to find this wire? This is driving me nuts!!!
Old 07-23-2009, 08:11 PM
2000CAYukon 2000CAYukon is offline
Re: Ignition timing bypass mode
On my 90, the bypass wire is under the black cover for the power distribution block on the passenger side of the firewall.
//2000CAYukon
Old 07-25-2009, 05:50 AM
Thanks for the reply. I finally found it. It was in the junction block on passenger side firewall as you said. Timing was way off, unplugged connector, set timing. Runs like new truck. Thanks.
