grand am fuel pump relays keep burnin out
i got the fuel pump relays keep burning out what would cause this
Re: grand am fuel pump relays keep burnin out
It sounds like a wiring issue, like something is shorted, or the fuel pump has a short and drawing too much current?
i changed the ignation switch today in the car cause it went the other day and now it won't start it kicks for a few seconds and dies out now and the cluster gauges went out
i did get it to run for a bit then i shut it off and i'd have to change the fuel pump relay then it would start again now it won't at all
Welcome to AF!
What year Grand am ?? Check the wire harness back to the tank from the fuse box. If you've had the tank off the harness can get damaged. Then check the fuse box for corrosion where the pump relay goes. Then if that's all good , and for your ignition switch you replaced, try this security relearn. ![]() Quote:
Hope that helps.
1999 Grand Am SS 3.4 OHV
