Old 07-19-2009, 01:32 PM
evans_usmc69 evans_usmc69 is offline
96 chevy k1500 tranny problem
I was driving down the road yesterday and I completely lost third gear. It shifts fine from park to 1st, 1st to 2nd, but when the transmission shifts to third, its the same as shifting into neutral. Anyone have any idea what would cause this?? I am not sure when the last time the transmission fluid was changed. I just got this vehicle a year or so ago, guess I should have asked. Thanks in advance.
Travis Evans
Old 07-20-2009, 02:11 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 96 chevy k1500 tranny problem
You should have some stored trouble codes. Beg/borrow/buy a code scan tool and post the codes back...but doesn't look good.
Definitely look at the tranny fluid. If it is low, clear to brown in color, or opaque, it is overdue to be changed. You can try a fluid change, but from your description, it's not the fluid...at least not anymore. If it had been shifting hard before this, those were your warning signs. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-09-2009, 12:47 AM
Merc 1500 Merc 1500 is offline
So worst case scenario, what do you think that is.? Because I have that same exact problem with my '93 K1500. And I've changed my tranny fluid, then checked it since then and its running clean.
Old 08-11-2009, 08:19 AM
jdmccright's Avatar
The RustBuster
Absolute worst case is you've lost one of the internal clutches, meaning you get to have the tranny rebuilt or replaced.
Less than worst case is you've lost a valve control (2-3 shift) solenoid or the valve itself or a check valve in the valve body has failed. This can be fixed by rebuilding only the valve body (meaning the whole tranny doesn't have to be removed). But a competent transmission shop should be able to tell you the extent of the problem.
If your check engine light is on (yours is OBD-I, so the codes can be retrieved w/o a scan tool), then hopefully its just a solenoid.
Extra thoughts...was the fluid low when you changed it? If so, are the any obvious leaks? If not, then you should check your vacuum lines from the transfer case switch mounted on the driver's side (three tubes coming out of the top). The internal seal can fail, sucking tranny fluid into the vacuum lines and into the front diff actuator diaphragm, the acumulator bulb and also out the tranny vent tube. The other possibility is that the seal between the tranny and transfer case has failed and fluid is leaking into the case, draining the tranny. Did the transfer case appear overfilled?
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 08-12-2009, 12:52 PM
Thanx for the help man, I'm saving up some money to take it to a tranny shop right now and keeping my fingers crossed that it isn't something real bad.
