Go Back   Automotive Forums Car Chat > Ford > Thunderbird
View Poll Results: Do YOUR leds function properly?
Yes 2 66.67%
No 1 33.33%
Voters: 3. You may not vote on this poll
Old 07-19-2009, 12:13 PM
Bob9646 Bob9646 is offline
Bad leds, cheapo fix?
Well, both my led rears gave up on me. And I just got a fix-it ticket last night. Around town here I have seen a large number of these cars that the trunk lights are totally out and just acting as reflectors while the corner lights are operating as brake/signals. This seems like a more viable option than chucking out 80 bucks for another set that will, without a doubt, fail. Does anyone here know how this is done? I assume you just cut the wires to the leds and wire them up to the corners but I just wonder if anyone knows the EXACT way to do this?
1996 Thunderbird lx 4.6L
Mods- PI top end swap, C&L plenum, 75mm throttle body, 03 mustang gt intake tube, airbox, 80mm MAFS, 300hp+ J-Mod, tuned really hot by Lonnie at Blue Oval Chips with an sct X3, mid length dual exhaust with mandrel bent X-pipe and turndowns
Up next- aluminum driveshaft, 22c plugs, 180 degree thermostat and a tune to match, polyurethane EVERYTHING, possibly lowering springs
Old 07-19-2009, 06:26 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Bad leds, cheapo fix?
Just unplug the LED reflector panels if you do not like how they look.
The panels are decorative and serve no other purpose.
Old 07-19-2009, 06:37 PM
Its not that I don't like the appearance, its that they are broken and I don't have blinkers or brake lights because the led panels are the blinkers and brakes...
Old 07-19-2009, 07:11 PM
Are your original, stock, corner, brake lights/turn signals not working?
Old 07-19-2009, 07:21 PM
I assume not... I've got that BLINKYBLINKYBLINKYBLINKY thing going on and I just pulled the bulbs out and they aren't burnt out... Should I complete the curcuit in the led lead with a wire and see if that helps?
Old 07-19-2009, 07:35 PM
Lol... I did all these mods here in my signature myself and I can't figure out tail lights
Old 07-19-2009, 08:03 PM
Get your original, stock, corner, brake lights/turn signals working.
That's what the "fix-it ticket" is for.
Old 07-19-2009, 08:14 PM
Ok thanks
Old 07-19-2009, 08:15 PM
Have your LED reflector panels been modified to function as blinkers and brake lights?
Old 07-19-2009, 08:17 PM
I didn't know that was a mod... Ok then the answer is yes
