Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-18-2009, 04:32 PM
dbikers dbikers is offline
How tight should timing belt be?
Hello All,
First time poster, first Isuzu (just bought it 2 days ago), it's got 102000 miles on it and have a couple of questions....my Rodeo "clacks" like a diesel at different RPMs (could be 1100, 1700, 2200, it doesn't matter)....when it's "clacking" i can rev it a bit and it's quiet then it starts again...from reading i believe it's timing belt/hydraulic tensioner related...other problem is that i smell antifreeze..my questions are:
  • how tight should the timing belt be? I pulled the pass side timing belt cover..i can see at least 1/4 inch slop when it's running and i can see the tensioner pulley bouncing like a basketball...the timing belt appears to be dry-rotted on the outside...again, how tight should it be...i think this may be an easy fix to get rid of the "clacking"...am i on the right track
  • smelling antifreeze...do these things have a history of cracked heads or bad head gaskets? Its not "spotting" anything but power steering fluid (as far a i can tell). I have never seen white smoke from the pipe and there is no loss of power, but there is some water that will come out the tail pipe when i first start it in the morning and let it idle for 10 minutes or so...oil doesn't look milky....overflow bottle was pretty empty..i have filled it and will keep an eye on it but wasn't sure if these were known for bad head gaskets.
Here are a few pics of it, i really like it and hope that i can get these items taken care of...
Old 07-18-2009, 04:50 PM
Andie_J Andie_J is offline
Re: How tight should timing belt be?
Your first problem sure sounds like the timing belt tensioner, there is no way to adjust it so it muct be replaced. It is a hydrolic unit that is prone to cause your symptoms when they go bad. Most do a new belt and water pump at the same time, if it hasnt been done recently. Andie
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
Old 07-18-2009, 07:06 PM
amigo-2k amigo-2k is offline
Isuzu Guy
The water out the tail pipe is normal on all cars in the morning. It is just condensation that builds up in the exhaust as the car warms up and then blows it out.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 07-18-2009, 10:28 PM
Cat Fuzz Cat Fuzz is offline
+1 on the tensioner being bad. You will need to be specific at the parts store. Most of them will hand over the pulley part, you need the little hydraulic pusher. You also should do your water pump and replace the belt while you're in there and inspect the other pulleys for noise and wear and replace as needed. The antifreeze smell could be a seeping water pump.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 07-19-2009, 08:00 AM
amigo2k, i also thought the same thing...once the car warms up there is no more water from the exhaust...
Cat Fuzz...i know that there are "kits" out there that sell the GMB water pump, tensioner, the idler, the belt and bolts...but none of them sell the spring loaded pusher...why is that...you'd think that every kit should include it? And, i'm not seein any antifreeze on the ground, i'd think if the water pump leaked i'd see it somewhere. Is this kit http://cgi.ebay.com/ebaymotors/93-97...5%3A3%7C39%3A1 from ebay ok to use? seems like the price is right...and where can i find the hydraulic piston tensioner?
Again, thanks all for your replies...i will reply once i have changed everythig...
PS i just had back surgery tuesday...i'm real sore right now (i could barely move after putting the pass side timing cover back on...i am real stupid, just ask corporate)...it's "embarassing loud", but can i drive it this way for a couple of weeks until i've healed a bit? it's either i drive it this way or i drive this in the mean time
I'm not even sure i can get in it right now? Thoughts?
Old 07-19-2009, 11:09 AM
well, i just orderd the spring tensioner, i will purchase the rest of the stuff in the form of an ebay "kit" if they are ok to use...pls advise about the kits from ebay that also include gmb water pump.
thanks in advance
Old 07-19-2009, 05:07 PM
There is no spring tensioner. The hydraulic piston is the only thing that keeps the belt tight. It pushes on the "tensioner" that you're buying in the kit. The terminology is a bit inaccurate. The tensioner you want you can get on rockauto.com. Look up your application, click 'engine' drop down and then find timing belt tensioner. There are several listed you want the one that says "GATES Part # T43095 {No Pulley Attached}"
Old 07-20-2009, 08:58 AM
this is the piece that i bought...
I want to buy like everything else at one time (tensioner, idler, belt, water pump) like in this kit http://cgi.ebay.com/ebaymotors/93-97...5%3A3%7C39%3A1
...looks like a popular water pump, only thing that scares me is what they say about the belt...."Timing belt (Sources: Conti-Tech, Bando, Goodyear, CADNA, etc.)"
if i buy all these parts individually it's gonna cost me a mint to make this ricer quit clacking....also, ok to drive for a month or so this way or is this a bad call?
Thanks
Old 07-20-2009, 09:14 AM
ha...i'm sure my terminology is off...i'm used to amc/jeep crap (oddly, i haven't found a singe reverse-torx bolt on this thing yet though i haven'et looked thoroughly...lol)
Its the same this as what i bought yesteday at thepartsbin...
I really want to buy this kit from ebay that has everything else..But am a bit concerned about the belt source "Sources: Conti-Tech, Bando, Goodyear, CADNA, etc..."
Would you trust the quality of this kit? Has anyone here ever used it?
Also, i will not be fit to do this stuff myself for probaby 6-8 weeks..i will not be driving for the next 3 weeks...will it be ok for me to drive my new ride 4 or 5 weeks with this clacking or would i be better to pay somone and get it done before driving (dayum, nobody touches my stuff $*&%!)
Thanks in advance
Old 07-25-2009, 07:49 PM
highlandlake highlandlake is offline
The body on that Rodeo is in great condition!
Is it a southern car?
About your question to drive it as-is or not......how badly dry-rotted was that belt?
Do you smell anti-freeze in the vehicle or under the hood.....that combined with the tensioner problem suggests that perhaps it should be driven only for short distances. Looks like you have other rides in the stable - park it until you have the parts.
Good luck - again that Rodeo is looking great for it's age and location.
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 07-26-2009, 05:33 PM
99 Fronty 99 Fronty is offline
'Hydraulic Tensioner' is a bit of a misnomer. This thing has a spring in it. The hydraulic part as I understand it is an oil through orifice shock absorber arrangement that stops the piston bouncing around. That's why when you re-compress them you have to do it slowly or you blow the seals out.
I could be totally incorrect as I've never had one apart.
'99
99 Holden Frontera SE (Isuzu Rodeo) 3.2 V6 DOHC
Victoria, Australia.
Old 07-26-2009, 08:00 PM
i was told by the po (he had it for 2 michigan which is like 27 dog years) that the car was from fla.
the belt didn't really look dry rotted, just loose and a little cracked (keep in mind i had just the left top cover off).
i smell antifreeze when i turn the ac on... not sure if it's the heater core or what...the only drop of anything that this thing leaks is ps fluid. with my back in the condition that its in i haven't been able to crawl under it to see if all the hoses are tight or what.
All the parts are on order and should be here in a few days (i already have the hydraulic spring tensioner) and then we'll see.
As far as rust, i will por the frame..have a few spots of surface rust (in rear door jams, not holes, just a little rust at the seam)...i will have to do someting with it also...i hope this thing runs up to the 240k i got on my ranger.
Thanks for all of your input/advise
John
Old 08-02-2009, 08:56 PM
Cat Fuzz and others...Quick question(s)
The timing belt tensioner bolt (for my SOHC) should be 168 inch pounds...i think that's about 14 or 15 ft pounds...what happens if it's over tight? Also, how tight should the bolt for the idler pulley be? I am sure it should be more than 168 inch pounds but can't (or haven't) find it in my HAYNES.
After tearing mine all apart (belt was bad anyway, i guess it was due) i found that the tensioner bolt was pretty stinking tight...i think that being too tight may have been part of the problem...not letting the tensioner float? Just a thought.
Anyway, am in process of putting all new stuff in...will be using some locktite as 15 foot pounds seems really light.
Thanks in advance for your help.
Old 08-02-2009, 09:17 PM
Overtightening the bolts risks breaking the bolt or stripping out the soft aluminum threads. Usually, if you just get them tight without going overboard, you should be good. The bolts came out hard because of being there for years and years.
Old 08-02-2009, 09:38 PM
gotcha, but would you think that the 14-15 ft lbs is enuff for the tensioner? I have been playing around a bit and found that if it's tighter the tensioner doesn't pivot very easily..]
either way, i will definately use locktite.
Thanks Fuzz
