Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 07-18-2009, 09:18 AM
j.psencik j.psencik is offline
1990 Cadillac Deville Brake Problem
I'm having a problem with the brake on the front driver side. The brake is dragging and sometimes not releasing. I have replaced the Callaper, Rotor, and Pads. The passanger front side is working fine. I have flushed the system, just thinking there might be some trash in the line and it is still doing the same thing only on the front driver side. Any info will help. Thanks James
Old 07-19-2009, 12:01 PM
DFBonnett DFBonnett is offline
Re: 1990 Cadillac Deville Brake Problem
Check the rubber brake line to the caliper. If it is degraded internally it can act a a check valve, holding pressure on the caliper.
Old 07-19-2009, 05:32 PM
maxwedge maxwedge is offline
A990 racer
Good info, DF. When this happens crack the caliper bleeder, if pressure releases it usually is the hose.
Old 07-20-2009, 07:11 PM
Thanks Guy's. I will check this out. The hose looks good on the outside, but I will pull it off and check the inside. Never thought of this. Thanks agian
