Old 07-18-2009, 08:45 AM
Bob B Bob B is offline
speed sensitive steering
Hi,
I have a 97 K1500. The steering has gotten hard while parking a few times. So I'm wondering if the speed sensitive steering might cause this?
I only have a 96 manual and there is nothing in this set about it. So I figured that the feature started in 97.
Any ideas?
Thanks,
Bob B
Old 07-20-2009, 03:20 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: speed sensitive steering
Speed sensitive steering? Sorry to say, but that would be a luxury for any truck. More likely, either the fluid is low or the pump or steering box is wearing out. Any excessive groaning while turning the wheel? Does it get easier if the engine is revved? Some steering fluid stop leak might help, but never a guarantee. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-20-2009, 05:40 PM
Well darn I guess I have a luxury truck then!
It was added in 97
Old 07-20-2009, 06:49 PM
777stickman 777stickman is offline
To verify you have the EVO (Electronic Variable Orifice) steering system on your truck, check for a wiring connection at the bottom back side of the pump.
If you do have this system, then yes, the EVO solenoid on the back of the pump may cause the trouble you are having. However, as posted above, it could also be the pump or box.
Try sucking all the old fluid out of the reservoir and replacing it with fresh power steering fluid a couple of times and see what happens.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 07-20-2009, 08:19 PM
MyTOY's Avatar
MyTOY MyTOY is offline
It took me less than an hour to replace my EVO sensor on my 97. They are about $70 at the dealer. If you crawl under your dash on your back you'll see it around the shaft with a connector going up towards the steering wheel. You just need a 15mm wrench for the shaft bolt & a small screwdriver for opening the retainer holding the sensor. The more common symptom is a slipping feel when going around a slight corner at a moderate speed. I hear you can have them tested. I posted detailed inst. here but it was a long time ago. I think you'll find a lot of info if you search EVO sensor. You need to be cautious around all the airbag business under the dash.
03 WRX
Old 07-21-2009, 05:30 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Originally Posted by Bob B View Post
Hi,
Any ideas?
Thanks,
Bob B
Usually what happens is the sensor goes bad and will cause a hard/loose condition while turning.
Replace the EVO sensor
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 07-23-2009, 01:16 PM
jdmccright's Avatar
The RustBuster
I stand corrected, thank you all.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
