Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-18-2009, 12:44 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Kinda random...
Ok, so coming right off my turbo, the way its set in there, there is a 90 degree silicone elbow that joints the first intercooler pipe to it. right now, i have a heat sleeve velcrowed around it, to keep the manifold thats right underneath it from burning it up. My question is, does anyone know if they maybe make a sort of plate style heat shield...like those u can get for other things...like air intake filters..i was wondering if anyone has ever seen a heat shield in the shape of a 90 degree bend basically...
I have exhausted my resources...cant find it...advice on making one maybe?
The purpose is bc the material from the sleeve on there now is slowly unraveling and making a mess of strings everywhere...and its ugly
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 07-18-2009, 09:37 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Kinda random...
You are deffinately going to have to make something. You could just wrap it in heat wrap.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-18-2009, 09:59 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Kinda random...
I would say get a 90* bend and use smaller couplers to connect it to the rest of the IC piping.
I never understood on the Hahn kits why you just don't take off the compressor housing and rotate the outlet downward. Is it because the piping is all precut to fit that exact placement? If so, I'd buy an extra piece and make it happen better. My t3 is shooting straight down and travels along the bottom of the radiator to the FMIC.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-18-2009, 10:29 AM
Holset powered 420a
Re: Kinda random...
Dave - This would be the ideal setup but you cant clock him compressor housing because of the internal wastegate. Hahn could have designed it like that but for some reason they thought this was better.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-18-2009, 10:45 AM
david-b's Avatar
Dave is THAT guy
Re: Kinda random...
Ah. I didn't know people use the internal gate on the Hahn setups. Always hated that 90* turn right off the housing. Looks bad and non-efficient.
75 Monte Carlo
Old 07-18-2009, 01:56 PM
Re: Kinda random...
Yeah this turbo can't be modded or anything...and all the intercooler pipes came with the kit, all pre cut, and the instructions are such that it tells you exactly which pipe goes where, ect.
So, some sort of bandage heat tape...would do the trick? Proctect the coupler further from high temperatures?
Old 07-18-2009, 03:14 PM
Holset powered 420a
Re: Kinda random...
Just buy some exhaust wrap, it will do the trick and look clean
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-18-2009, 09:52 PM
Re: Kinda random...
Good idea...some black heat wrap...thatll be much better looking...thanks man
Old 07-20-2009, 12:48 AM
Re: Kinda random...
something like this will do good?
http://prosportgauges.com/fiberglass-header-wrap-1.aspx
Old 07-20-2009, 08:32 AM
david-b's Avatar
Dave is THAT guy
Re: Kinda random...
Originally Posted by boostjunkie333 View Post
Yes
75 Monte Carlo
