Prep for smog test
I need to get my car smog tested, its a 1986 IROC with a 305ci and TPI.
Im planning on using Royal Purple fuilds, K&N filters, E3 spakeplugs, and getting a new smog/air pump. Is there anything else I should do to get it ready?
El Destructo Inc. present Michael Stoneman Im not so good with advice... Can I interest you in a sarcastic comment. |
Re: Prep for smog test
not really... as long as your check engine light isn't on... no faulty sensors (reporting atleast). check that all vaccum hoses are properly connected.... and EGR isn't stuck open. You can probably do a search about it. Probably not even worth the effort of checking, unless you have notice any significantly reduced gas mileage.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
