Old 07-17-2009, 07:03 PM
spankthaspeedbump's Avatar
spankthaspeedbump spankthaspeedbump is offline
engine swap issues
I have a 1993 f150. I had to change the engine. The engine I found, was out of a 1995 f150, both engines are a 5.0L. The firing order for the 1993 was 1-5-4-2-6-3-7-8 and the firing order for the 1995 is 1-3-7-2-6-5-4-8. I have the engine in and it is running really rough. I left in the original distributor for the 1995. Do I need to change the distributor or the camshaft to make it run correctly? I put the wires on the distributor the same as it would be on the 1993 firing order. The engine sounds like it is running on 6 cylinders.
Old 07-20-2009, 09:15 PM
Re: engine swap issues
hey guys, any thoughts on my above question??? please don't let this one fade into the forum archives...
Old 08-04-2009, 11:09 PM
carguyzack34 carguyzack34 is offline
did you replace the entire engine or use parts from both engines?
