Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-17-2009, 05:22 PM
dpj52190 dpj52190 is offline
Send a message via MSN to dpj52190 Send a message via Yahoo to dpj52190
Cool all lock/unlock stopped working in front passanger side
Hi i have a 1994 camry le 4 cylinders. 117k miles. and for some reason the all lock/unlock stopped working in the front passenger side. If I press all lock/unlock, all of the doors lock/unlock except the front passenger side. The buttons works fine on both sides. the nob doesn't turn in the front passenger side.
any help on how to fix this.?
Old 07-19-2009, 09:31 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: all lock/unlock stopped working in front passanger side
Sounds like the lock actuator motor in that door has broken or is too weak to move it. The only way to fix it is to remove the door panel and repair/replace it...not an easy thing given the depth of the door. You cannot see inside there and space is limited for any tools.
My Cam has the exact same problem (sometimes it works but most of the time the lock knob just twitches or goes half-way) and have yet to figure out how to even get to it. My thought is to unbolt the door latch receiver and extract it from the door, expecting the actuator to be connected, then go from there to diagnose the problem. Any others in here with experience in fixing this are welcome to chime in.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-19-2009, 12:56 PM
Cool Re: all lock/unlock stopped working in front passanger side
i tried to open it. but it seems like the actuator is connected with the lock hinge. Couldn't get to it so i just quit. but thanks for reply..now atleast I know the what is causing this problem...
