Old 07-17-2009, 12:04 PM
kbaird83 kbaird83 is offline
Ticking?
i have a 02 w/ the 5.3l. just today i started hearing a ticking noise when at idle. i dont hear it at acceleration. its not very loud. it doesnt seem to have any set speed or rhythem to it just a random yet constant tick. and it doesnt stop once warmed up. oil change w/ in last 300 miles used valvoline 10-30 and it is not low on oil. any one else have this?? what is it?
Old 07-17-2009, 01:53 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Ticking?
Sounds like something's up with the valvetrain. First and most likely thought is a collapsed or partially-collapsed lifter. If the little disc check valve in one of the hydraulic lifters gets crud lodged in it, it can't maintain internal oil pressure needed to prevent slop (or lash) in that valve assembly. But when you rev the engine, more oil is circulated and overcomes the lifter's leakage rate, restoring the zero lash.
Other thoughts are a sticking valve or weak valve spring, but in these cases, the ticking typically happens at higher revs since the valve/spring can't respond fast enough to keep up with the lifter. So i'm gonna lay me bet on the first one.
I'd first try a good engine cleaning like Seafoam to try and dissolve the gunk/crud that's stuck in there. Then, unless you want to hunt down the offending lifter and fix it by removing the valve, you can abate it by adding some oil treatment additive like Lucas Oil, Restore, or the like. You're already using 10W-30 so a more viscous oil like 10W-40 is possible, but that's a stretch...you don't mention your odo miles, but higher numbers can lend itself to more wear. '02 should be in the 105k-130k miles range...a bump up to high-mileage and semi-synthetic or full synthetic might help too.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-17-2009, 03:33 PM
Re: Ticking?
it has 101,000 miles. it just started and it doesnt sound like a lifter because there is no rhythem to it. its just a spuratic tick.
Old 07-17-2009, 09:26 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: Ticking?
pour can of seafoam into the cranckcase, drive on it for about 500 miles, change oil.
Old 07-18-2009, 06:38 AM
silveradofirerescu silveradofirerescu is offline
Re: Ticking?
get out, she's gonna blow!
Old 07-18-2009, 08:12 AM
ukrkoz's Avatar
Re: Ticking?
don't be a child, seafoam is completely safe to drive on. i have anywhere from 500 to 2000 miles with it in on my cars. read instructions on the can.
Old 07-18-2009, 09:01 AM
Re: Ticking?
calm down, i was talking about the ticking... like a bomb going tick tick tick
so dont be a d-bag
P.S. it is interesting that you immediatedly assume that I am attacking Seafoam, a product in which I openly neither know anything about nor use. So who are you trying to convince that it is a good product? Don't be so defensive about things, I am not attacking a product you love, I simply saw a thread title that said "ticking" and it made me think of the explosive reference. You seem a little uptight, maybe you should drink some seafoam, walk around for 5 to 20 minutes and change your oil.
I'm just sayin, might feel better.
Last edited by silveradofirerescu; 07-18-2009 at 09:30 AM. Reason: don't like being called a child
Old 07-18-2009, 10:31 AM
ukrkoz's Avatar
Re: Ticking?
so dont be a d-bag
that's cool. we'll both agree that your post could be treated both ways, as derogatory to seafoam - and as a funny joke. so yes, if it was a joke, i do take my remark about "being a child" back and apologize. of course, calling me dushbag is not warranted either, but even that i do find funny.
peace. seafoam is a great product, helped many with all kinds of problems, personally used for years on all kinds of vehicles.
sorry, can't fill your 2nd request, i do not drink, smoke, lie, and eat meat. helps me to stay philosophical on things that are not worth anger. i have been through craigslist automotive forum school, that'll hone peaceful mindset in anyone.
have a great day.
j cAT j cAT is offline
Re: Ticking?
any nosie you need to use something to locate the area of origination.. I use a hose and one end next to my ear the other to probe for source of noise...
could be water pump..
Old 07-18-2009, 10:33 AM
ukrkoz's Avatar
Re: Ticking?
hose, hah...
i like that. i used wooden stick before, but hose should be better sound transmitter...
thanks for the tip.
Old 07-18-2009, 10:47 AM
Re: Ticking?
have a great day.
Hey, I am not holding any hard feelings towards you, just felt I was being attacked for something I did not intend. I also understand your POV as people have been slamming seafoam in some recent posts and you are probably tired of that. But, I did not intend it to be a slam on seafoam. So, anyway, see you around
Old 07-18-2009, 07:04 PM
jyount jyount is offline
Re: Ticking?
hose, hah...
thanks for the tip.
nope, a stick works better, but it is not good when you get it in moving parts, a hose just flaps around, a stick tries to take you ear with it.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 07-18-2009, 11:49 PM
Re: Ticking?
its deffinatly from inside the motor. the only thing i can think of is it started right after i started running some stp fuel system cleaner through it. i know that stuff made with most jet fuel (says so right on the bottle) maybe its from the higher combustion? i dont know run a couple tanks through and see if it goes away. then try some sea foam and if all else fails get it fixed throught the warrenty i guess
Old 07-19-2009, 08:21 AM
ukrkoz's Avatar
Re: Ticking?
interestingly enough, out of all cleaners out there, STP is the only other one i use regularly. it is made by g'ol Studebaker-Packard, very old company, and i have tendency to stick to firms that have been around for long time.
sounds like you "unglued" something.
does the tick go away when engine warms up? GM pushrod engines have "morning sickness", when lifters are not yet quite filled with oil and rockers have more slack than on hot engine.
btw, you did NOT run stp through cranckcase, did you? it's, vs seafoam, strictly fuel treatment. so, it cleans only fuel tank/lines/pump/injectors/anything fuel is going through. not much tick to made by those. pump is all the way back under your buttocks.
injectors? those are, basically, check valves, with solenoids, that close/open letting fuel in. that'll make shy ticking noise. i'd say - get mechanic stetoscope and pinpoint tick.
Old 07-20-2009, 05:48 PM
Re: Ticking?
no i dumped it in the gas tank. stp is the only fuel treatment i will use as well and have never had any problems with it. im just trying to figure out if its related or coincidence. im going to run another full tank through then if no change take it in and have them do the work on it.
