Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 07-17-2009, 08:06 AM
richamer1 richamer1 is offline
Send a message via Yahoo to richamer1
Air Bag Light Code.
2000 Venture. At startup the Air Bag light blinks then stays on solid sometimes not always. Does this also set a code that I can read and has anyone else had similar issues ?
Old 07-17-2009, 04:44 PM
roadrunner2 roadrunner2 is offline
Re: Air Bag Light Code.
I don't think there is any code for the airbags. (FWIW, Haynes doesn't show any in the code list)
If your van has the drivers power seat and also has the front seatback side-mounted air bags, check the wiring connections (harness) under the drivers seat and the front passenger seat.
I had a 2000 Silo with this fault and it turned out to be a dirty connection under the drivers seat.
I disconnected it, sprayed electrical contact cleaner in each connector, applied a little dielectric grease, reconnected and never had a problem after.
The problem with doing nothing is not knowing when you're finished.
Old 07-17-2009, 05:04 PM
maxwedge maxwedge is offline
A990 racer
There are air bag codes, a high line scanner can access this info, no other way short of, as suggested, finding something disconnected, careful fooling with this system, though.
