Old 07-16-2009, 11:28 PM
Marty232 Marty232 is offline
2004 overheating
hi,
i have a 2004 cavalier that starts to heat up with alot of stop and go driving. red lights , stop signs, etc. the car only has 28,000 miles on it.
Old 07-23-2009, 05:26 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2004 overheating
Cooling fan probably isn't coming on. Check that it runs, if not check the fuse (replace if blown) and for power and ground at the connector for the fan.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-26-2009, 11:01 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
If its hot outside, and your doing stop and go driving... yea, its going to do it.
Moving should read 1 click below 195, in traffic at stop lights I go between 195 and half way to red until fan kicks on. Fan will also remain on when key is pulled and cars engine is still above 195.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
