Old 07-16-2009, 03:50 PM
paulp64131's Avatar
paulp64131 paulp64131 is offline
No Label
Replaced Ignition Switch now wont turn off.
I had replaced my ignition switch last year when I was troubleshooting a No Start scenario. The problem was not the ignition switch. However, after it while the new switch failed. When I would turn the ignition off everything like radio, heater... would stay on after you would exit the car or open the door.
So today. I put the old ignition switch back in. And it appeared to work fine. Except now. If I turn the ignition off while my foot is on the brake, the car won't shut off. As soon as I release the brake, the car shuts off. If I put my foot on the brake with the key in the off position, all the dash lights come on as if I put the key to on.
Any ideas?
Thanks
PAULP64131
2003 Jeep Grand Cherokee Overland
4.7L H.O. Inside
"Roads? Where we're going, we don't need Roads."
Old 07-16-2009, 04:18 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Replaced Ignition Switch now wont turn off.
Sounds like the old switch it bad.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
