Old 07-16-2009, 08:15 AM
jmlr74 jmlr74 is offline
2002 little power
my 2002 silverado with 4.8 will start and run but put in gear it has no power. wont rev over 1500 rpms. possible cat blocked or fuel filter?
Old 07-16-2009, 10:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2002 little power
May be one or several of many things.
What is the mileage and when was last good tune up?
What is the fuel pressure readings?
Any check engine lights on or flashing.
For a plugged exhaust post back vacuum readings at idle and 2K RPM.
MT
Old 07-16-2009, 12:47 PM
138,000 miles. bought truck in november 08. just changed plugs. no change. engine light came on and flashed when first acted up. havent done any testing yet. out of work right now but when i get the funds i will test fuel pressure. is there special tool for testing fuel pressure.
Old 07-16-2009, 01:16 PM
MT-2500's Avatar
AF - Advisor
Check for codes and if light is flashing when running you have a cylinder mis.
Post back code no.
MT
Old 07-16-2009, 01:29 PM
thanks for your help. i will post back when i figure more out. the light is no longer on but i havent gone any where with it . since it barely moves.
Old 07-16-2009, 01:30 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
IT could possibly be the mass air flow sensor. My Silverado acted up almost the same way and that is what it was. But as suggested, get the codes scanned, it can get costly just guessing and throwing new parts at a problem when you are unsure.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 07-16-2009, 01:34 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You should be able to borrow a fuel pressure tester from the parts store. It connects to a quick-connect fitting on the fuel supply line (looks like an A/C connector but should be near the firewall on the driver's side). A low pressure could be a failing fuel pump ($$$) or a bad fuel pressure regulator ($).
What happens when you try to rev it past 1500 rpms? Does it feel like the truck tries to move? Does the engine sound like it is bogging (no missing or roughness) or does it start to stall?
Another possibility is the O2 sensors are due for replacement.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-16-2009, 04:56 PM
it sounds okay in park but in gear it wont rev over 1500. it boggs down.
Old 07-16-2009, 05:09 PM
when it first acted up i was driving about 25 mph i stepped down on the gas pedal and bogged right down. when id hit the gas the engine light would flash and it wouldnt rev over 1500rpms. i changed the plugs and unhooked the battery and changed the plugs. took it down the road and light came back on and flashed as i stepped on gas still no power. i un hooked the battery again. then the next day hooked it back up and started the truck. starts right up but in gear wont rev just boggs down. thanks for the help.
Old 07-17-2009, 01:07 PM
kbaird83 kbaird83 is offline
is it 2wd and if so doesnt it have the traction assist unit?
Old 07-17-2009, 02:02 PM
jdmccright's Avatar
The RustBuster
The code reading should be free at the parts store as well as the fuel pressure tester loaner. Just because the truck's CEL isn't on doesn't mean there aren't stored codes. It will keep the trouble code history until it is cleared by a scan tool.
Another thought could be the throttle position sensor based on your description of symptoms. It could be errantly reading a wide-open throttle, feeding too much fuel for the air being taken in.
Check the codes & let us know what you find...at least that's free.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 07-18-2009, 10:52 AM
silveradofirerescu silveradofirerescu is offline
Simple thing, check all of your fuses. I had a similar situation where I blew a fuse that basically shut down the left bank of my engine, making my V8 a 4cyl. I believe it was the fuse for the injectors, and the SES light flashed scaring the crap out of me. But checking fuses is free and well, hey you never know.
Old 08-12-2009, 06:11 PM
JUST hooked to obd2. codes P0122, P0300 AND P0443. Is throttle position senser causing random mis.
Old 08-12-2009, 07:28 PM
MT-2500's Avatar
AF - Advisor
No.
Proper testing will give the answers.
Have you done any testing as asked for?
MT
Old 08-13-2009, 09:49 AM
j cAT j cAT is offline
I would check the throttle position sensor connector for damage corrosion....then If necessary using an OHMMETER measure the resistance while moving the throttle to see if the resistance drops out to infinity[open]...3 wires gray , blue, and black...black is common [ground].
the blue is the connection that will vary resistance as the throttle is changed..
gray is the PCM/computer reference voltage feed of 5volts,,when the engine /ignition switch is on...
this is very possible .....as your problem..let us know what you found..
