Old 04-02-2003, 10:06 PM
tEk4000 tEk4000 is offline
Exclamation speedo is out!!!
My speedo just went out today...actually it comes on for a few seconds but then disactivates. So my v-tech is affected aswell, i don't get the boost at any rpms... i have even redlined and no v-tech...it sucks...the little boost i had is now gone...any one with any ideas
Old 04-03-2003, 02:48 PM
94civic's Avatar
94civic 94civic is offline
check the speed sensor. look for any cut wires or anything that is broken. also check behind the gauges and see if any of the harnesses behind there are messed up.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 04-03-2003, 06:17 PM
Thanks where would i find the speed sensor...
Old 04-03-2003, 06:23 PM
zippeay zippeay is offline
There should be one or two bundles of wires going into the transmition check to make sure there both plugged in. There both not in the same spot so check all over the trans to make sure you find them
Old 04-07-2003, 04:04 PM
funkdaflex1 funkdaflex1 is offline
you should check your vtec solenoid if u still havent figured it out
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 04-08-2003, 11:06 AM
devonic devonic is offline
vtec solenoid not working will cause your speedo to stop working?
Old 04-09-2003, 10:44 AM
I checked for burnt wires or something that llooked odd, i thook it apart checked the valve, and i had no visual problems. How could i get the solenoid tested before i decide to buy a new one???How mucwould one run for?
