Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-16-2009, 12:59 AM
zann121 zann121 is offline
My brake lights dont work.
Hi,
All 3 of my brake lights stopped working. When i checked the fuse and replaced it. Now everytime i press on the brake the fuse burns. i tried over 4-5 fuses and they all burnt one after the other. Could it be a problem with the brake light switch? i checked for any short but i didnt seem to find any. please help me. thank you
Old 07-16-2009, 07:48 AM
Copytech99 Copytech99 is offline
Re: My brake lights dont work.
You have a short, The fact that the fuse opens when you step on the brake indicates the short is in the line after the brake switch. (between the output of the switch and the bulbs)
Do you own a meter with an Ohms setting ??
What make and model vehicle ??
Old 07-16-2009, 01:04 PM
I have an 1998 Honda accord SEDAN . What should i exactly do now?
Old 07-16-2009, 02:07 PM
You will need to identify the wire color used for the brake light circuit ( I had a factory manual on CD and it is missing)
You will then need to bare some insulation from that wire or use a sharp meter probe to pierce the insulation near one of the bulbs and see if a dead short is present on that line( It will read 0-1or2 Ohms resistance with reference to ground)
Has any work been done recent ?? Changing of bulbs in rear ??
Old 07-16-2009, 04:11 PM
The wire color for the brake circuit after the switch appears to be GREEN/WHITE.
It may be easier to remove all 3 brake bulbs, The resistance of the 3 in parallel will be quite low with them in place.
