Old 07-15-2009, 09:56 PM
roo1113 roo1113 is offline
2000 gtp wont idle
hello i have a 2000 gtp. just the other day i had an issue.. at idle my car dies... if you hold it to the floor that is the only way it will stay running. it is not a fuel pump changed that then changed it again to make sure.. hooked up fuel pressure gauge turn key on goes up to 48 psi... start it goes up to 55 psi then start bleeding off pressure rapidly unless i hold it to the floor... then when car dies fuel pressure goes right back up to 48 psi... any ideas i am lost fuel filter not that old either but chaning it tomorrow let me know need help thanks...
Old 07-15-2009, 11:37 PM
doctorhrdware doctorhrdware is offline
Re: 2000 gtp wont idle
It could be your fuel pressure regulator? Pull off the vacuum hose and see if you smell gasoline fumes or if gas comes out of the vacuum hose. But with the pressure bleeding down like it is also could be fuel leak. Do you smell any gasoline fumes.
Old 07-16-2009, 07:50 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
You may have a bad fuel pump resistor. There is a proceedure in our tips and maintenance sub-forum on how to bypass it to test.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-16-2009, 04:11 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
x2 on the resistor.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-16-2009, 04:15 PM
I keep forgetting about the fuel pump resistor. I get a demotion point on me. LOL
