4wd don't work
have a 99 chevy and the 4wd does not work. I shift it to 4wd and i can hear the actuators work on the front drive shaft and the encoder on the rear. I can also shift into 4 lo and it goes there but the front wheel still won't work. I also lifted the front wheel off the grond and in park and 4wd I can turn the front drive shaft and the front wheels will turn. No service 4wd light is on
Re: 4wd don't work
From your post I might think that it's something in the t-case since you can spin the front drive shaft with it in park and in 4wd.
Do the indicator lights come on showing that the shift into 4HI or 4LO is completed? Is it a push button or floor shift? Do you have "auto 4wd"?
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Re: 4wd don't work
Yes the lights indicate that it does indeed go into 4wd. and it does have the automatic 4wd
Re: 4wd don't work
I have the same truck and pretty much the identical problem only mine will work in auto 4wd but like yours not in 4 hi or 4 lo.I asked a mechanic friend and he says it sounds like the shifting forks inside the trans case are not fully shifting.I'm hoping to yank mine out sometime this summer or early fall to see what's going on inside but will likely just buy a rebuild and slap it in rather than tear into mine.I've priced the parts to rebuild mine and by the time all is said and done it is almost as cheap to do a swap plus there's less down time with the truck.
Re: 4wd don't work
1st thing for both of you is to drain the t-case and replace it with the GM "autotrac ll" fluid. This fluid is blue in color. Also check the fluid you drain out for metal particles. Drive it around for a couple of weeks. May help, may not. The auto 4wd t-cases have clutch packs in them for the "auto" function.
With the lights telling you that the encoder motor is going to the selected position (not blinking) then there may well be an internal t-case problem.
Re: 4wd don't work
the transfercase fluid trac II needs replacing when the color is gray...when the transfercase fluid gets to old this will cause many of these problems and possibly a new transfercase.. the front diff actuator locks the front axles together,,,this has nothing to do with loss of 4WD...the encoder motor does that.. |
Re: 4wd don't work
Re: 4wd don't work
Thanks for the advice. I figured the T-case was bad inside but I wanted to see if there was something that I may have missed. I just bought the truck and it was a repo and has had the #%$@ beat out of it.
Thanks again |
Re: 4wd don't work
Old thread I know, but I am having the same problem as these guys. What is the function of the encoder motor? Why would I hear the truck shifting when I go to 4hi, but I have no power at the front wheels? I guess my only hope is to change the fluid in the t-case, and if nothing else the t-case itself?
Re: 4wd don't work
Re: 4wd don't work
I'm assuming there would only be drive train failure codes if the service 4wd light was on, which mine is not. I disconnected the plug from the front axle locking actuator and I still here something engaging. I assume this has to be the encoder motor?
When I select 4hi or 4lo the light will blink and then stay lit. just a little more info |
Re: 4wd don't work
with checking for those codes this would be the correct proceedure if you are sure it is indeed not in 4wd..the transfercase could be internally broken where the encoder moves but the fork does not. lift front wheels off ground when in 4wd can you rotate any front wheels ? if so then it is defective. also check that the front wheels are locked together. |
Re: 4wd don't work
I am sure it is not in 4wd because when i put it in 4wd and spin in dirt it is only the rear tires that are spinning. Thank you for the fast replies!! And if you notice, I changed my previous post... |
Re: 4wd don't work
if you remove the encoder you can check this out. post back what was broken.
Re: 4wd don't work
I believe this ---> http://www.chevyavalanchefanclub.com...c,41895.0.html
is the t-case in my truck, and if so it shows how it works EDIT: The transfer case above is the 05+ upgrade. They talk about the differences in the article. Last edited by ratchets; 04-23-2011 at 10:33 PM. |
