Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-15-2009, 04:17 AM
workinmanfred workinmanfred is offline
Idler arm
I have a 95 CV with 107,000 miles on it and I am going to replace the idler arm. When I do the idler arm, do I also have to replace the pitman arm on the other side? The idler arm side has a lot of play, but not the pitman. Should they both be done at the same time? I value your opinions, especially yours way2old, you're cool.
Old 07-15-2009, 06:20 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Idler arm
If the pitman arm has no play, we usually do not replace it. Unless you just want to do it while you are working on the steering anyway. We usually inspect all steering parts each time and replace what is bad. If there is 3 or more parts bad, we usually replace all steering linkages. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-04-2009, 07:32 PM
BITTERMAN45 BITTERMAN45 is offline
Re: Idler arm
at that mileage you should check for play in the inner and outer ball joints and upper and lower control arms.
Old 10-03-2009, 10:36 AM
97cv's Avatar
97cv 97cv is offline
Re: Idler arm
LOL WUT ?
Upper and lower ball joints ...
