Go Back   Automotive Forums Car Chat > Buick > Buick Classics
Buick Classics Discuss older classics here.
Old 07-14-2009, 10:39 PM
CWUSMC's Avatar
CWUSMC CWUSMC is offline
Question 87 Regal T Type Tranny shifting....
Ok I put a 350 from a 74 corvette into my regal I have a 350 turbo sitting behind it that I bought completely built with red line clutches and Kevlar bands the whole works - today it changed its whole stance on me..... It dosent go into 2nd gear until its at around 35-45 mph and when you hit 60-70 it shifts again
It chirps the sh*t out of the tires at 2nd gear that I dont mind but i would like for it to shift earlier i checked all fluid and she looks toped off
69 Charger R/T 440
83 T-Type Regal 3.8 Turbo
87 Regal 350 Chevy 460hp
~~~ Go Baby Go ~~~
R.I.P.
09/11/2007
2007 Charger 3.5L H.O.
Cause of death: Hit by 16 year old girl who had her license for 2 weeks and no insurance
Only owned 3 Mo.
Old 07-15-2009, 12:51 PM
maxwedge maxwedge is offline
A990 racer
Re: 87 Regal T Type Tranny shifting....
Have you adjusted the tv linkage properly?
Old 07-15-2009, 03:42 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
As I recall, the THM 350 does not use a TV cable. That is used in the THM 700, THM 200 and THM440 transmissions.
The THM 350 has a modulator, which is essentially a switch that uses intake manifold vacuum to control the shifts.
Late shifting will occur if the modulator is stuck or the vacuum line has become disconnected or blocked.
The hot set-up is to use an adjustable modulator, because, when properly set-up, it can compensate for low vacuum conditions caused by long-duration cams.
Old 07-15-2009, 07:02 PM
A990 racer
My 350 in a street rod has kick down linkage that can alter shift patterns. I assumed after all the work he did the modulator would be properly connected, maybe you are right here.
Old 07-16-2009, 09:51 AM
CWUSMC's Avatar
looking around I don't see any vacuum lines that arnt connected and the kickdown cable is adjusted correctly there about a 1/2 in of room for it to travel where its connected to the carb. - I have been manually shifting it and if I do it myself everything seems to be fine I'm wondering if the modulator went bad.
69 Charger R/T 440
~~~ Go Baby Go ~~~
R.I.P.
09/11/2007
Only owned 3 Mo.
Old 07-16-2009, 08:16 PM
MagicRat's Avatar
My money is on the modulator. Just check that the vacuum line going to the mod actually has full vacuum (I suggest use a vacuum gauge) at idle, before replacing it.
I had to look this up in my transmission rebuild manual. The THM 350's cable performs a more limited function than the TV cables in the 4 speed automatics. The manual refers to it as a kick-down cable, not a TV cable as such.... but as you say, if its out of whack the shift points will be incorrect.
Old 08-21-2009, 02:21 PM
430-4 430-4 is offline
hi, first thing to do is determine if it has a vacume modulator. small round vacume control device usally located on the passenger side toward the front of the tranny case on turbo 350's. let us know & we can go from there.
Old 08-21-2009, 09:29 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Don't forget to check the servo & governor springs. See pic below for locations.
