Old 07-14-2009, 04:04 PM
crazytaz crazytaz is offline
1990 cherokee stalling
well in case anybody else had the same symptoms as me if it will run while in crank position but stall as soon as key was returned to run position check the ballast resistor on the 1990 cherokee it is the white ceramic peice on the drivers side front fender wall cost about $5 at autopart store easy fix
Old 07-14-2009, 06:22 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1990 cherokee stalling
How many miles?
This is one of the symptoms of a bad Crankshaft Position Sensor - it just dies.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-14-2009, 06:52 PM
Hmmm yeah, with the start button there may be some electrical issue....and I'm not the one to help diagnose it. Someone should be along shortly with some help.
Old 07-15-2009, 08:47 PM
not to my knowledge.
Old 09-01-2009, 02:20 AM
oljeeptek oljeeptek is offline
Umm, this resistor was a fuel pump resistor to drop voltage running for noise reduction. If it goes, it'll cause die out as the pump isn't running except during cranking.
It looks like the old ballast resistor and the symptoms are indeed similar.
Remember...
Old Jeeps never die, they just sometimes look that way!
