Old 07-13-2009, 08:33 PM
rzbeamboy rzbeamboy is offline
99 Silverado shifts hard
My 99 Silverado automatic shifts hard from 1st to 2nd.If I shut it off for 10 min it is ok. Any ideas? Thanks!
Old 07-13-2009, 08:42 PM
j cAT j cAT is offline
Re: 99 Silverado shifts hard
THIS USUALLY MEANS that the transmission is slipping in OD..then the pcm/computer commands the transmission to maximum line pressure,,which causes the harsh up shift...
when the engine is off this is then reset....
having the transmission examined for DTC . OEM specific drivetrain scanners required...not the generic type...
It is possible it is just a dirty filter or transmission fluid is shot..
IF YOUR LUCKY....
Old 07-13-2009, 08:46 PM
Thanks I will try a filter and fluid change
Old 07-13-2009, 08:51 PM
If it is not the trans filter and fluid, could this be areal costly problem?
Old 07-13-2009, 09:23 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
don't guess, it's usually too late when your guess turns wrong. MANY have same issue, it's f-d up design. i fixed mine by replacing filter, doing fluid change, and adding lucas trannie oil.
Old 07-14-2009, 07:06 AM
ColoradoSilverado ColoradoSilverado is offline
When this happened to me I just installed the TransGo shiftkit, transmission has been fine ever since...
Bert
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 07-14-2009, 09:48 AM
yes.. $2,000.oo
Old 07-14-2009, 07:49 PM
Thanks all ! Bert what is a Trans Go shift Kit ? Was it hard install?
Old 07-15-2009, 07:09 AM
The TransGo Shiftkit is a set of parts to be installed in the valve body of your transmission, it's not that hard to install just take your time. I found my shift kit on Ebay for $35, this was the "professional" kit.
It's like this one: http://cgi.ebay.com/ebaymotors/GM-4L...%3A1|72%3A1171
Bert
My Truck:
My wife's Truck:
