Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 07-13-2009, 03:47 PM
Piperdp Piperdp is offline
1992 tercel ac problem????
I have a 92 tercel had ac recharged no leaks blew cold air for about a week now the compressor turns on but no cold air ??
Any help would be GREAT
Old 07-14-2009, 12:26 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 1992 tercel ac problem????
If your system required alot of refrigerant to recharge (more than one 12-oz can) then you have a significant leak and need to find & fix it first before wasting more money on recharges and refrigerant.
Second, make sure that the A/C compressor is actually engaging when it is turned on. You should hear the click of the clutch, the engine rpms increase slightly, and the radiator cooling fans turn on. But if it doesn't, it could be the clutch, its circuit, or the low-pressure switch preventing the compressor from turning on...again usually due to low refrigerant.
An A/C manifold gauge set can show you what condition your system is in, but should be checked by qualified mechs if you're not familiar with reading and diagnosing the pressure readings. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
