Old 04-02-2003, 07:42 PM
freelunch's Avatar
freelunch freelunch is offline
A Future Floor Wax FAQ
Here's what I've learned about future floor wax so far:
-Cheap $6.99/750mL at Superstore
-Glossy
-Smells nice but doesn't mean its healthy to breathe it in
-Self Leveling
-Can be airbrushed/handpainted with q-tips, widebrush etc.
-Thinned/Dissolved/Cleaned with windex, isopropyl alcohol
-It is NOT as tough and hard as everyone says - It can be scratched/dented by a careless fingernail so please don't abuse it.
-try not to get water droplets or let a futured surface stay wet for a long time - surface will partially soften and get cloudy until it dries out again. At this time the surface is very fragile.
**If you get heavy orange peel with future, a way to fix the situation sometimes is to clean your airbrush by spraying alcohol through it. Instead of spraying this alcohol into a waste container, lightly mist it onto the future floor wax'd surface to remelt and hopefully get a smoother finish.
Best results for airbrushing:
-20 PSI
-unthinned
-airbrush 5-6 inches from surface
-don't linger over the area - pass over quick with no hesitatiton to avoid buildup
-make sure surface looks uniformly wet with no orange peel -haziness and clouds which may appear will clear as it dries
-avoid overspray; overspray will develop into orange peel and should be sprayed over with more future to even it out
Old 04-02-2003, 07:48 PM
daggerlee's Avatar
Future is also very cleanable with ammonia. Spray some Windex, or generic window cleaner, or anything that contains ammonia through your airbrush.
Some modelers on rec.models.scale actually thin future 50/50 with rubbing alcohol.
Dan
Old 04-02-2003, 10:57 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Thanks for that.
Steve a.k.a. Hiroboy
Old 04-02-2003, 11:50 PM
Ghost_9418's Avatar
Ghost_9418 Ghost_9418 is offline
Cool, I found out that theres a bottle of future underneith my sink.
Ryan
If your new to the AF modeling forum please read this : AF modeling FAQ
Current Project:
Tamiya Porsche Boxster Special Edition
Old 04-03-2003, 12:12 AM
Mainomega Mainomega is offline
Oh, add this to the FAQ...
Mainomega can't spray this right if his life depended on it.
Thanks
Got Something Good ? E-mail me
Old 04-03-2003, 05:07 AM
935k3's Avatar
935k3 935k3 is offline
Thanks
Try wiping it on with a clean tissue or cloth. With practice it works very nice.
Old 04-03-2003, 05:12 AM
Deejay27's Avatar
Deejay27 Deejay27 is offline
Can you polish this stuff once it has completely dried?
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 04-03-2003, 03:24 PM
yellow15's Avatar
yellow15 yellow15 is offline
Yes you can polish it. i sand it using 2000 tamiya sandpaper and then use T-cut to polish it and looks really shinny after that. (but don't wetsand it)
Old 04-03-2003, 05:48 PM
Vric's Avatar
Vric Vric is offline
so Future Floor Wax can make a better clear coat as Spraycan Clear coat ?
Never think of using that
is it this ?
Old 04-03-2003, 06:12 PM
flyonthewall's Avatar
Car Mod guy
That's good!
I have a Q! When airbrushing what can you clean it with after? Is water enough to do it?
Old 04-03-2003, 07:20 PM
935k3's Avatar
That's good!
Use clear ammonia to clean.
Old 04-03-2003, 07:35 PM
freelunch's Avatar
When ever I polish future floor wax with Tamiya compound it always leaves the surface hazy with lots of little swirls. What's up?
Old 04-03-2003, 08:20 PM
daggerlee's Avatar
There are better polishable clear coats than Future. Future gives the best shine without polishing, though.
Dan
