Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 07-13-2009, 08:29 AM
bribri10307 bribri10307 is offline
Question 96 Lincoln mark viii wont start
I have a 96 lincoln mark viii and lately its been having trouble starting. the majority of the time it starts, but on occassion it just keeps turning over but doesnt start. the other night, i had no power at all, but the next day it started perfectly fine after playing with the battery cables. What could be wrong????
Old 07-13-2009, 10:42 PM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: 96 Lincoln mark viii wont start
sounds like you may have two problems one easy the other more of a challange. the easy one would be no power- pull both terms off batt clean with wire brush on both batt and cables reinstall and tighten. that should fix no power no turn over. next and it really at this point doest matter what size eng because all gas engines need air mixed with fuel going in compression spark to egnite and exhaust unrestricted. so when car turns over but doesnt start you need to know if there is fuel at least at fuel inject rail and or is there spark .one of these will not be present when car turns over yet no start. repost when you know whats missing and then eng type would help
Old 07-14-2009, 05:05 AM
mikemark8 mikemark8 is offline
for the hard starting problem when it cranks but doesn't want to run, Marks have a tendency to need the crank sensor replaced or possibly just removing and reinstalling the connector (after cleaning it up)-facing the engine from the front of the car, it is at the 7 o'clock position of the crankshaft pulley, next to the air conditioning compressor. If you replace it, you need to jack up the right (passenger) side (don't forget to shut off the air ride switch), loosen the serpentine accessory belt, loosen (don't have to remove) 3-10mm bolts that hold the ac compressor to the engine and remove the 8mm bolt (easier done from up top IMO) that holds the crank sensor to the block. A new sensor is about $25 and it is a 30 to 45 minute job, I have owned a couple of marks and found that it solves stalling or erratic starting problems on both. Hope this helps.
Old 07-16-2009, 01:47 PM
thank you very much, I appreciate the help but I think we have decided to just put it in the shop, rather than trial and error, we already tried spark plugs wires and the coils, so at this point spending more money on things that are perfectly fine is just pointless, but again thank you very much!!!!!!
Old 04-13-2012, 10:49 PM
spree spree is offline
I wish you would have told us what the problem was! I had the same problem and it was the fuel pump. Replaced the pump and been running fine for 3 years now
